Discussion topic: Sky Q remote not working
This message was authored by: Hina5
Re: Sky Q remote not working
Hi
im having a problem with the volume not working can someone please help
thanks
@Hina5 wrote:
Hi
thanks
@Hina5 Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Jacqueiln+Duncan
The sky q box in the bedroom is not working ok
Can you describe a bit more what is happening?
Is the box powering on, or are you getting error messages on screen, if so what do they say?
This message was authored by: LittlePerker
I have sky glass but use Sky Q with it. I had to do an update when the TV wouldn't turn on, since then the remote doesn't work properly. I did the 1 & 3 and 7 & 9 reset which paired the remote so the volume now works but the quick search bar at the bottom of the screen is appearing twice, I can be on the Home Screen moving up & down but it is also controlling the search bar (shows you the next programme & channel) moving that up & down so doing 2 actions at the same time.
This message was authored by: Dunn001
Worked perfectly 👌 Thanks for posting.
Pity Sky aren't more helpful themselves.
This message was authored by: John777
New batteries were placed in the remote control for the hub. I don't think this improved matters. What did work, though, was to unplug the hub for 30 mins. and then tried again. All working fine! There was no need for remote reprogramming. Good luck 🙂
