Discussion topic: Sky Q remote not fully working
This message was authored by: Alex+Houston
The volume, channel and record options have stopped working on my SkyQ remote.
Re: Sky Q remote not fully working
Hi @Alex+Houston
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Failing this
Check out the following link.
Click still need help and then click get in touch after ticking the box that you have tried online help.   This will lead you to a form for free remote replacement.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
Avatar for Alex+Houston
Have already tried that trouble shooting option bt still not working.
Hi @Alex+Houston
