Discussion topic: Setting up Sky Q apps - on PC/tablet
Message posted on 22 Mar 2023 01:06 PM
Is it possible to set up all of the Q apps on remote devices - rather than on the box itself ?
Message posted on 22 Mar 2023 01:09 PM - last edited: 22 Mar 2023 01:12 PM
Re: Setting up Sky Q apps - on PC/tablet
If you are referring to the likes of Netflix, Amazon Prime, Disneyplus, Dsicovery plus, ITV X - then the answer is a Yes
Many are available on many platforms & personally I think better on the other devices - I only use the apps on SKY Q to test something
Edit : BTW Even Paramount plus that requires initial set up via SKY Q is availble on other platforms (I use a PC, Tablet & Firesticks)
Message posted on 22 Mar 2023 01:10 PM
Hi @Anonymous
Only Apps that you subscribe to or are available for use on other devices.
You have no control of other Apps on Q.
