3
This discussion topic has been answered Discussion topic: Sky Q remote control
This message was authored by: Stationwagen
How can I purchase a new sky Q remote control from sky?
This message was authored by: mike+simmonds Answer
Re: Sky Q remote control
Hi @Stationwagen
You may not need to purchase one. Sometimes Sky will just send you one depending on the circumstances
here is a link
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
click on - still need help
Sky customer since 1989.
Sky Q 2TB main box
LG CX6LA from 2020
Hi @Stationwagen
here is a link
Sky Q 2TB main box
LG CX6LA from 2020
@Stationwagen
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken or faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (I’m not sure if this is available to customers in the Republic of Ireland).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer / larger supermarket.
While your waiting, if you have an android or Apple device with Sky Go you can possibly set up a virtual remote to control your Sky Q box. See this link which may help
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Avatar for Stationwagen
Did all that and it worked. Thank you.
