Discussion topic: Sky Q remote control doesn’t work properly
This message was authored by: Batster2668
My Sky Q remote control for my secondary box doesn't work properly
Re: Sky Q remote control doesn’t work properly
Hi @Batster2668 .
First reboot the
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your minimbox back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your remote or if this is not working press the standby button on the front of the Q box (Amber led)
If the remote stil isn't working
With the mini box on with green led try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the remote led flashes and follow onscreen instructions to re- pair.
Failing all this
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
