Discussion topic: Sky Q remote control codes for Seiki SE32HY02UK
This message was authored by: SFTO
Message posted on 20 Aug 2023 05:27 PM
I have 2 Seiki TV's SE32HY02UK and SE32HD01UK and neither will pair with my Sky Q remote controls. Where can I find the codes please?
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 20 Aug 2023 08:04 PM
Re: Sky Q remote control codes for Seiki SE32HY02UK
@SFTO if Seiki isn't coming up as a brand there should be an option to choose other brand find this option for other brands and try the codes in the other brands failing this you could also try the codes under Vestel
