Discussion topic: Our Sky Q box stopped working couple of days ago, followed steps and worked.
This message was authored by: Trev20
Sky q box stopped working followed steps then ok but has done it daily and now main box says no subscription but account has multiroom ? And sky q
Re: Our Sky Q box stopped working couple of days ago, followed steps and worked.
@Trev20 id firstlytry refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet to see if that clears the no subscription problem,
If it does then Have you tried rebooting your main Q box ie
then
do the same with the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
