Discussion topic: Sky Q recording faults
This message was authored by: GOLDJAG
We often find recorded programme is showing the progress bar as almost finished when we try to play it for first time after recording
Re: Sky Q recording faults
hi @GOLDJAG
This can happen if you watch the channel, even for a brief period whist it is recording - the marker that stores progress may be set by watching the channel.
We think this is aimed at people wishing to pick up where they left off but most people probably would prefer it not do this
If you don't press the watch from start button and start watching part wy through just use the voice command "Go to Start"  to start from the beginning
 Hi @GOLDJAG
Apart from this happening because you have briefly watched the program maybe inadvertently it will also happen if the program is currently onscreen when you start recording.
