Discussion topic: Sky Q randomly shuts down
This message was authored by: DFY
Sky Q box will randomly shut down irrespective of whether we're watching live tv, Netflix, recording on Sky etc
D
Re: Sky Q randomly shuts down
@DFY You could try resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
