Discussion topic: Sky Q pin problems
Message posted on
24 Sep 2023
05:38 PM
- last edited:
25 Sep 2023
09:34 AM
by
KevNewMedia
Sky Q pin problems
Tried inputting pin number but will only accept 1st number?
Moderator note: subject of thread updated to better reflect the conversation
Message posted on 24 Sep 2023 05:44 PM
Re: Sky glass will only accept 1st number of pin
Sorry meant Sky Q!!
Message posted on 24 Sep 2023 07:36 PM
Do you mean the first digit @JulieJevins .
Even if you don't use the correct digit it will still accept more than just one digit. Obviously will not accept the Four digits if incorrect.
You are not not trying to press select after each digit are you?
Message posted on 25 Sep 2023 08:18 AM
Yes, first digit when asked for pin number, pressed 2nd digit when moved to next box, wouldn't accept. Tried to reset pin as instructed by inputting last 4 digits of account from where bill is paid, accepted the 1st 3 digits then same as above! Very strange, never had this before and always used same pin 😡
