9
This discussion topic has been answered Discussion topic: Sky Q options
This message was authored by: Ouseman
Sky Q options
I want to see a list of the different channels, features and costs of a 1TB Q box, a 2TB Q box, and their 4K versions, but I can't find that anywhere on the Sky website. ANy suggestions?
This message was authored by: Chodley Answer
Re: Sky Q options
@Ouseman wrote:
Thanks but I have no idea what a 32C, 32B1 and 32B2 box are - I thought you said they're all the same!
Subscription cost (there is no purchase cost, you can't buy them) and channels are the same.
features differ in terms of the things he mentioned.
you can't really pick and choose what you get anyhow but these days everyone gets a 1TB box that can do UHD/HDR
Re: Sky Q options
@Ouseman
The channels don't change from Sky Q box to Sky Q box. Channels are based on the subscription and add-ons you take. The default Sky Q box at the moment is a 1TB.
Re: Sky Q options
Hi @Ouseman   The subscription cost is the same for all boxes, as is the features and channels. Apart from 32C that only records 3 channels at a time and supports only one Mini box simultaneously. All 32B boxes support UHD and 32B1 & 32B2 boxes support HDR. The current default is the 32B2 1TB box.
https://www.sky.com/help/articles/sky-software-updates
Avatar for Ouseman
Re: Sky Q options
Re: Sky Q options
Re: Sky Q options
Hi @Ouseman   They are the hardware versions of the boxes. As far as the end user is concerned they are all the same.
Re: Sky Q options
Until they need to do a box replacement and assume the old power cable will fit 😁
Avatar for Ouseman
Re: Sky Q options
Thanks to everyone who answered. The fog is clearing!
Re: Sky Q options
hi @Ouseman
Just in case of any confusion over the different boxes the default box being offered to new customers is a 1TB UHD (HDR capable) box although for customers upgrading from SKY HD we have often seen SKY only offer the older 1TB non UHD box
2TB boxes are fairly thin on the ground and usually SKY will want an 'upgrade' fee of typically £99 there may also be an upgrade fee if they are only offering the non UHD version
To put this in contect with earlier posts the 32xxxx reference is what is shown in the menus on the boxes
If it is 32Cxxx then it is an older 1TB non-UHD Box
If it is 32B0xxx then it is  a (V1) UHD but non HDR 2TB Box
If it is 32B1xxx then it is a (V2) UHD HDR 2TB Box (which has a separate Power supply)
If it is 32B2xxx then it is  a (V3) UHD HDR 1TB or 2TB Box (as mentioned the 1TB version is now usually the default for new customers)
As you may see the mention earlier regarding differng power supplies is with the 2TB versions
Note you are unlikely to specify you get a 2TB V3 box above only a 2TB HDR capable box which SKY can issue a V2 or V3
Note V1,V2 & V3 are terms only really used here and the SKY advisers do not know them by these (or even the 32xxx references) only by type e.g. 1TB non UHD/1TB UHD, 2TB UHD non HDR capable & 2TB UHD / HDR capable
Avatar for Ouseman
Re: Sky Q options
Thanks very much. That's v clear and helpful
Answered - Go to Answer
