Discussion topic: Sky Q no internet
This message was authored by: Budgie1
Sky Q no internet
My sky q box tells me I have no internet but my sky router has 4 green lights and sky service checks tells me everything is ok
Re: Sky Q no internet
Hi @Budgie1
Avatar for Budgie1
I've tried that with the help of a sky helper it does work for a short time but it stills drop out again it seems it might be the area where we live
No, it's the Q having rubbish wifi. It's not telling you the internet connection itself has a problem, it's telling you that IT can't get to the internet.
Which router do you have?
Avatar for Budgie1
I do have a sky router biggish square one with 4 green lights
What colour and/or model? Is it the Max router?
Avatar for Budgie1
It's black I can't see a model name on it sorry
Ok so it shouldn't be the Max one (which I believe is white) which has more compatibility issues with the Q.
Presumably it's been working fine before? What happens if you reset the network on the main Q box with any minis completely powered down?
Avatar for Budgie1
After a reset it all seems to work for a short while then it's back to showing no internet on the q box
