Discussion topic: Sky Q no WiFi
Message posted on 12 Mar 2024 09:13 AM
Sky Q no WiFi
Hi, my sky Q box has lost wifi connection in the middle of watching a programme on Disney channel. I've tried network connection using the WPS several time - no joy - I then unplugged the whole system and still nothing. Any help would be appreciated
Message posted on 12 Mar 2024 09:41 AM
Re: Sky Q no WiFi
Hi @GaryM54
Assume you are on Sky Broadband if you are trying to connect by WPS?
Did you do this by carrying out a Network Reset on the main Q box?
Message posted on 12 Mar 2024 09:51 AM
Re: Sky Q no WiFi
Hi, thanks for your very comprehensive reply and I can confirm I tried all those steps. I have now arranged for an actual Sky engineer to visit later today. 👍
