Discussion topic: Sky Q multiroom box
Message posted on 18 Jul 2023 05:00 PM
Sky Q multiroom box
my tv has not been turned on for a while but when i did it says it is rebooting the sky q box and then goes totally blank. cannot get onto sky at all. Can anyone suggest anything?
Message posted on 18 Jul 2023 05:02 PM
Re: Sky Q multiroom box
Hi @Dom+Shaw
First make sure that the TV is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will work for all TV’s.
Message posted on 18 Jul 2023 10:00 PM
Still not working...... it just goes blank after first reboot page
Message posted on 18 Jul 2023 10:10 PM
Message posted on 19 Jul 2023 02:26 AM
Yes it was
