Discussion topic: Sky Q multi screen will not connect
Message posted on 21 Jun 2025 08:48 AM
I've had Sky Q multi screen for years. Today it is telling me I don't and I need to upgrade to use it
Message posted on 21 Jun 2025 09:16 AM
Re: Sky Q multi screen will not connect
Hi @Penmad
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
