Discussion topic: Sky Q multi room keeps cutting out
Message posted on 02 Jan 2024 10:14 AM
Hi
For the last 2 weeks the multi room sky box keeps cutting out, it says on the settings that it is connected to the internet and to the sky Q box, I have reset it multiple times and also reactivated it to the main sky Q box but it still keeps regularly cutting out.
Message posted on 02 Jan 2024 03:00 PM
Re: Sky Q multi room keeps cutting out
@Naomi1986 wrote:
Hi
@Naomi1986 Have you tried rebooting your main Q box ie
then
reboot the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
