3
This discussion topic has been answered Discussion topic: Sky Q miniboxes connectivity
This message was authored by: Sharnick
Hi, can anyone help with this issue please? I've changed broadband provider from Sky to Virgin Media and have connected my Sky Q box to my new Virgin WiFi hub. However, I can't connect my Sky miniboxes to either the Q box or the hub. Does anyone know how I should do it please? Thanks in advance for any advice.
Re: Sky Q miniboxes connectivity
Hi @Sharnick
Afraid the mini will only connect to the main Q box if using WiFi on 3rd party (non Sky) Broadband.
Reboot the mini as above.
If the mini still does not connect try a Network Reset on the mini.  Start with the mini nearest to the main Q box.
When carrying out the Network on the second mini you can use WPS with the first connected mini if nearer than the main Q box.
Hi @Sharnick
Avatar for Sharnick
Thanks for this, I'll give it a try.
Avatar for Sharnick
This worked perfectly. Thank you very much.
