Discussion topic: Sky Q mini
This message was authored by: TacksInspector
Sky Q mini
Hi Guys
I was getting a lot buffering when my Q box was wifi connected so I connected the box to my WiFi extender - TP-Link. Via  an ethernet cable in the hope that a wired connection would reduce or even eliminate the buffering.
Since doing so, each time I switch on my tv I need to reset my Internet connection.
Is there some other setting that I need to adjust? All is ok once I reset the box. Anyone else tried this?
Re: Sky Q mini
Check your Standby mode, if it is Eco or None change it to Active. This MIGHT solve your problem. Go to settings, then Setup, then Preferences.. On the right look at Standy Mode. If it is not set to Active then that might be your problem. Worth a check methinks, it might fix your problem.
Re: Sky Q mini
@Anonymous
That solution is for a specific issue which (again) in this thread is not the problem.
