7
This discussion topic has been answered Discussion topic: Sky Q mini remote
This message was authored by: Chigirlx
Sky Q mini remote
Is it the same remote the main box has please. I have it due to be installed and like a cover to protect my remotes. Asking before I buy the covers
Re: Sky Q mini remote
@Chigirlx wrote:
I assume the mini box comes with a remote?
Hi @Chigirlx
Yes they do.
All Q boxes come with the latest Voice control Bluetooth remote.
https://www.sky.com/help/articles/q-buttons-explained-voice
Hi @Chigirlx
The original covers will not fit the  latest Bluetooth Q remotes that have the front microphone button.
Avatar for Chigirlx
Level 4 icon
Hi @Chigirlx
Yes they do.
Avatar for Chigirlx
Level 4 icon
Are both remotes the same?
Avatar for Chigirlx
Level 4 icon
Thank you for helping me. I just wondered because my email says this. No mention of the other remote for the mini
The equipment listed below is loaned to you by Sky at no cost and must be returned to us at the end of the relevant subscription.
Sky Q 1TB UHD
Sky Q remote
Sky Q Mini box
Hi @Chigirlx
Yes all remotes are now the latest version with front Microphone button for Voice control which is available on all Q boxes.
If you are having Sky Q installed then the Engineer will bring all Q boxes.  He should install the mini as well as the main Qbox and you can check that there is a remote for each box.
Avatar for Chigirlx
Level 4 icon
Thanks so much. I'll just plug in the mini myself while he's here as it's a tight squeeze in my bedroom. I only need to plug it in and add the wifi password to see it's working before he leaves.
