Discussion topic: Sky Q mini error mr001
This message was authored by: Dhomewood
I've just got a new sky q mini box for my office at home but it currently won't connect to the main sky q box. I keep getting error mr001. Has anybody been able to resolve this?
Re: Sky Q mini error mr001
Hi @Dhomewood
Assume the mini came from Sky and you have the monthly Q Multiscreen subscription?
Reboot the mini as above.
Avatar for Dhomewood
Thank you for replying.  I've tried everything with no luck and I'm currently trying to get in contact with sky customer services to get a booster but no luck so far.
This message was authored by: K.L.Richards
Alot of posts on this. I had the same problem yesterday after Sky help got me to factory reset my router (which wasnt needed).
Anyway, after battling to sort the MR001 issue with my mini boxes not connecting to the main box, I remembered that for them to connect using the MPS button, they have to connect to a 2.4Ghz Wifi channel. If your Sky Router is set to combine the 2.4 & 5Ghz band into one SSID, then you have to disable the 5 GHZ band first. You can then connect the mini boxes, by following the onscreen intrsuctions using the MPS button. When they are connected you can re-enable the 5Ghz channel on the router.
This message was authored by: BKaur
But how do you do this??
