Discussion topic: Sky Q mini connectivity problem
Message posted on 07 Feb 2026 10:08 PM
Keep losing connectivity although service checker indicates internet connection is good.
Message posted on 07 Feb 2026 10:29 PM
Re: Sky Q mini connectivity problem
Hi @JDi1
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
