5
This discussion topic has been answered Discussion topic: Sky Q mini box
This message was authored by: Slugwig
Sky Q mini box
I haven't used my mini box for a very long time and have just reconnected- I'm getting terrestrial channels and I can see my recordings made from the main box, but can't access sport or movies etc
Re: Sky Q mini box
Do you definitely still have an active Multiscreen subscription?
I'd think it's also possible that the Mini is several firmware releases behind the current version and may not behave properly until it's caught up.
Re: Sky Q mini box
@Slugwig  what message are you getting if any if you try to watch sports or movies
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Sky Q mini box
Avatar for Slugwig
Re: Sky Q mini box
Yeah, thanks I updated the mini box software and it resolved itself- thanks for responding
Avatar for Slugwig
Re: Sky Q mini box
Sorted now thanks - software update required to mini box 👍
This message was authored by: Skycruiser
Re: Sky Q mini box
I have switched everything off and rebooted 3 times with the main Sky Q box and the mini box. I still have error MR104. By the way I have also rebooted my broadband which is working correctly. Can anyone help, this is so frustrating especially when I have had all my sky hardware replaced less than 6 months ago.
