Discussion topic: Sky Q mini box.
Message posted on 17 Aug 2025 05:03 PM
Sky Q mini box.
Can I add another mini box to my main box?
Message posted on 17 Aug 2025 05:12 PM
Re: Sky Q mini box.
Hi @Gothiccomic You can add up to 4, but depending on your Main box, you can only use 1 at a time with a 32Cxxx box, or 2 at a time with a 32Bxxx box.
Message posted on 17 Aug 2025 05:16 PM
Re: Sky Q mini box.
@Gothiccomic
As stated above you can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+. It’s worth mentioning that UHD content can’t be viewed on a mini box.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
Re: Sky Q mini box.
Hi @Gothiccomic I should add, make sure you get it from Sky and don't be tempted to buy a plastic brick from elsewhere.
