This discussion topic has been answered Discussion topic: Sky Q mini box
Message posted on 07 Jul 2025 05:26 PM
Every time I use my Sky Q minibox I have to reset the permissions in the main box and restart the mini box. Otherwise it just sits there saying do not switch off and will be ready soon.
anyone else have this problem and any ideas?
Message posted on 07 Jul 2025 07:19 PM
Hi @TS1964
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Hi @TS1964
