Discussion topic: Sky Q mini box
Message posted on 25 Jul 2023 12:33 PM
Sky Q mini box
I've just received a new sky Q mini box I also have 2 others and didn't know that I can only watch 2 at the same time. I'm not sure why I wasn't told this when purchasing this new box as it's not really any use if my 1 of my rooms can't get it
Message posted on 25 Jul 2023 12:51 PM - last edited: 25 Jul 2023 12:55 PM
Re: Sky Q mini box
@cecelia01 wrote:
I've just received a new sky Q mini box I also have 2 others and didn't know that I can only watch 2 at the same time. I'm not sure why I wasn't told this this new box as it's not really any use if my 1 of my rooms can't get it
Hi @cecelia01
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
You can have up to four minis installed on loan each subject to a one off upfront charge and all under by one single Q monthly Multiscreen subscription
However only two minis can be used simultaneously on all 2 TB boxes and the 1 TB UHD Main boxes to watch Sky Q content.
The original 1 TB non UHD box only permits the use of one mini at a time.
If Sky Apps are already being used on some of the minis these will not normally be counted as in Q use and therefore can be used in addition to the above limits.
See the following link for the Versions of main Q box referred to above.
https://www.sky.com/help/articles/sky-software-updates.
Subject to the above limits Sky Q minis can be used completely independently of the main Q box and the same or different program or recording can be viewed on each Q box. Even if viewing the same content it is completely independent and can be viewed at the same or different point.
Minis can do all the features same as the main Q box and can set or delete recordings on the main Q box hard drive. There is one single storage area on the main Q box with no profiles and no indication of which Q box has set a recording. (Unlike Sky+HD Multiroom which has independent storage and planners).
It should also be remembered that minis cannot view UHD recordings or content.
