Discussion topic: Sky Q mini box
Message posted on 16 May 2023 10:53 PM
Sky Q mini box
I have a Sky Q 2B box and 3 minis I am aware that I can only use the main box and 2 minis at the same time but tonight only one mini box works with the main one on as when I try to watch one of the other mini boxes it says to many connected which is not correct. Does anyone know why?
Message posted on 17 May 2023 06:52 AM
Re: Sky Q mini box
hi @SimonJake
Not too sure why but sometimes I think the 'count' gets confused.
We generally suggest a full power down restart of all boxes:
The first thing is to restart your main SKY Q box :
Use the remote to place it into standby mode
Then remove the power to it (either switch off at mains or remove the power plug)
Wait at least 30s
Then re-apply the power & wait for it to fully restart - this may take a few minutes.
Once the main box is restarted do the same power down on each of the mini boxes.
Message posted on 17 May 2023 09:01 AM
Re: Sky Q mini box
Hi thanks i will give that a go.
Message posted on 18 May 2023 10:34 PM
Re: Sky Q mini box
No this has not worked, any other things I can try?
