4
Discussion topic: Sky Q mini box
This message was authored by Laundradees This message was authored by: Laundradees
Sky Q mini box
Sky Q mini box seems to contantly buffer.  Started last Thursday.  Sky Q main box is fine as is the wifi. Dees the sky Q mini box have a shelf life?
This message was authored by oldfella This message was authored by: oldfella Answer
Re: Sky Q mini box
Hi @Laundradees
Did you you also try the suspect one in the location of the other one.
Re: Sky Q mini box
Hi @Laundradees
No real wearing parts in a Q mini box.
Reboot the mini as above.
Laundradees
Re: Sky Q mini box
Did all that. I have tried the  sky Q box from another room and that seems to be ok
Re: Sky Q mini box
Hi @Laundradees
Laundradees
Re: Sky Q mini box
The ufffering stopped but now my Wifi keeps dropping out and I also have to switch the wifi off at home when using our iphones.
