This discussion topic has been answered Discussion topic: Sky Q mini box showing EPG but no programs
Message posted on 24 Nov 2025 05:31 PM
Hi wondered if anybody else had this issue, the mini connects to the main box ok, EPG appears as normal but whichever channel I select I just get a blank blue screen. Even recorded programs are the same, all recordings appear but when one is played I just get the same blank blue screen. I rebooted the box multiple times but no change.
The main Q box is working normally.
Does it seem like the mini itself is goosed?
Message posted on 24 Nov 2025 05:33 PM
@snowball2
Try a reboot of the main Sky Q box first, then once that’s back up and running do the same with any mini boxes -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
@snowball2
Message posted on 24 Nov 2025 05:39 PM
Re: Sky Q mini box showing EPG but no programs
The reboot and power off on the main box did the trick, thanks
Message posted on 01 Dec 2025 10:07 PM
This worked for me too! Thanks 🙏🏻
