Discussion topic: Sky Q mini box says programme unavailable.
This message was authored by: jacjarv
I have just got Sky Q and have multiscreen. The mini box worked perfectly the first day, but couldn't get any sky channels next day. It just says Programme Unavailable. When I check settings, it says all connected both on the mini box and main box. I have got multiscreen so that's not the issue. Tried all the usual reset options but nothing has worked. Very frustrating.
Re: Sky Q mini box says programme unavailable.
@jacjarv
What are you trying to watch on the mini box and on what channel?
Hi @jacjarv
Reboot the mini as above.
Avatar for jacjarv
ITV, BBC, SPORTS, EVERY CHANNEL SAYS 'PROGRAMME UNAVAILABLE'.
@jacjarv
Have you carried out the reboots as suggested above by @oldfella
Avatar for jacjarv
Thanks for that, but it didn't work. Still showing 'Programme unavailable'.
Avatar for jacjarv
Yes I have. The strange thing is both the main and the mini box show everything as connected and confirms I have multiscreen. Another message has appeared saying I might not have the correct subscriptions, but I definitely have.
@jacjarv I have escalated this to sky
You may receive an email or a private message inviting you to have a private conversation on the Community with a Sky Expert.
Look out for a chat bubble at the bottom of your screen inviting you to a chat
If you are using the Safari browser please make sure that Hide IP Address is not checked in order to see the chat bubble. If you are having trouble finding this to check the settings, use another browser such as Firefox, Chrome etc.
The link below explains how the escalation process works
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent an invite to jacjarv.
This message was authored by: Mr+Flibbles+86
We are still looking to help you. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Avatar for jacjarv
Sorry I missed your invite! I have booked an engineer to come this weekend now, so hopefully, he will sort it for me. Thanks for your help.
This message was authored by: DaniellaC0497
Hi, did his get sorted for you, I'm having the exact same problem with mine I've tried all the reset options, software updates etc and nothing works, just wondering if you have a solution?
Hi @DaniellaC0497 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot, and do the same with the Mini box?
This message was authored by: SamS12345
@jacjarv  How did you get this resolved? I have the same issue 😞
This message was authored by: MinaFirenze
@jacjarv Did you get this issue resolved? I'm having exactly the same problem and have had an engineer attend as well as the mini box replaced but still not working. Any suggestion on what the issue might be because Sky dont seem to have a clue.
