Discussion topic: Sky Q mini box not working
This message was authored by: GillyE84
My Sky Q mini box isn't working. I switch on at mains and a red light comes on but nothing else happens, nothing comes up on screen and light just stays red. I've tried doing what it says in troubleshooting advice like resetting etc but still nothing. My main box and my other mini both still work fine. Do I need a new box?
Re: Sky Q mini box not working
Hi @GillyE84
Have you tried switching the mini on using the Standby button on the front right of the mini (the Amber led)?
If this brings the mini on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for GillyE84
Level 0 icon
Yes I've tried that as I thought it was the remote to start with and yes I've pressed the button on the front too. Done everything it's suggested on troubleshooting. Thankyou
