5
This discussion topic has been answered Discussion topic: Sky Q mini box not showing programmes
This message was authored by: gilltone
Recently downloaded the SkyQ app to my iPad. May be coincidence but the next time I tried to use my SkyQ mini box, error message appeared for all channels - even BBC which requires no subscription. Message reads "Please check your subscription entitles you to view this channel on this box".
Apps like Netflix, Channel 4+ etc work and I can see (but not play) recordings. Done all the resets, downloaded software, unplugged from mains etc. Main Sky box has all the ticks for the mini box supposedly connected but it's like the Sky Multiroom subscription is no longer applied so the mini box won't show programmes or recordings.
Tried calling Sky technical team but just referred to Community - impossible to speak to someone.
Anthony
This message was authored by: MightyQuinn Answer
Re: Sky Q mini box not showing programmes
Hi @gilltone   Have you tried power rebooting everything, starting with the Sky Q main box.
Edit: Sorry, I see that you have ...
Avatar for gilltone
Yes, I actually unplugged both boxes last midnight and switched them on again at 8am..... no difference, problem still persists.
i saw one post on another thread which said cancelling and reinstating the multiroom subscription fixed it......
Avatar for gilltone
First time on the community... I pressed the answer button in error!
Hi @gilltone   No problem, I believe that if you press it again it should remove it (only guessing).
@gilltone If you have accidently marked a post as the answer then if you click on the 3 dots on the right hand side of the post marked as the answer then click on not the answer it should remove it failing that any superuser should be able to unmark a wrongly marked answer
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
