Discussion topic: Sky Q mini box not connecting
This message was authored by: AliRhona
My 3rd party router has just been upgraded to a new box.  I have been able to connect my sky Q main box but am unable to connect the sky Q mini box.  I have done all the things recommended in similar threads but still can't connect.  So far I have switched off the mini box at the mains, pressed and held the reset button till the stand by button  flashes red and green, pressed the home button when the screen goes blank, but nothing happens on the TV (it says no signal).   I have also pressed the stand by button when the stand by button flashes red and green but still no signal.  I have also changed the settings on the main Sky Q box of the standby mode from eco to active, and still not able to get the sky Q mini box to work.  Any suggestions?
Re: Sky Q mini box not connecting
Hi @AliRhona .
Reboot the mini as above.
