Discussion topic: Sky Q mini box keeps freezing
Message posted on 17 Nov 2023 09:06 PM
have reset it and the main sky Q box but still having issues With a lot of channels
Message posted on 17 Nov 2023 09:09 PM
Re: Sky Q mini box keeps freezing
Hi @Emma87
you may have already rebooted but try the following again.
Reboot the mini as above.
Message posted on 17 Nov 2023 09:14 PM
Hi thanks for your reply I have done all those steps my main sky Q box is in the living room and the mini is in the kitchen the sky broadband router is near the main sky Q box and the distance between the main box and the mini is literally 5 meters. I already have a sky Wi-Fi booster in the hallway between living room and kitchen this has been happening for a long time now and it's driving me crazy is there anything else that can be done before I need an engineer out
Message posted on 17 Nov 2023 09:18 PM - last edited: 17 Nov 2023 09:20 PM
Hi @Emma87
Exactly what did you do when you carried out a network reset on the mini box?
edit
Also is the booster a Sky Q booster
Message posted on 17 Nov 2023 09:23 PM
Home then settings then setup went to network went to the status and clicked reset. Is there any other way of doing it
Message posted on 17 Nov 2023 09:23 PM - last edited: 17 Nov 2023 09:25 PM
Message posted on 17 Nov 2023 09:27 PM
Yes it's a sky Q booster (everything in the house connected to the Wi-Fi is working great)
Message posted on 17 Nov 2023 09:28 PM
Pressed the WPS button on the main box
Message posted on 17 Nov 2023 09:33 PM
Message posted on 17 Nov 2023 09:36 PM
Yes it connected again after (now as we speak it's working but no doubt it will start freezing again as it's been doing this for a while now) the skyQ booster would be positioned exactly half way between the main box and the mini
Message posted on 17 Nov 2023 09:44 PM
Hi @Emma87
Assume the Q booster has been connected to the Sky Router by WPS or is it connected to the main Q box by WPS?
Either way if the booster is nearer to the mini than the main Q box then you need to connect to this by WPS after the Network reset (and not the main Q box)
