Discussion topic: No signal on mini box
Message posted on 17 Nov 2023 08:36 PM
No signal on my mini box
Message posted on 17 Nov 2023 08:40 PM
Re: No signal on mini box
Hi @Leannehynd
Reboot the mini as above.
Message posted on 17 Nov 2023 09:03 PM
Our sky tv is not working, it is say viewer card is not inserted
