Discussion topic: Sky Q mini box keeps freezing
This message was authored by: JandL88
Hi, wondering if someone can help as not getting much of a response from Sky. Since Saturday our sky q mini box keeps freezing on live tv and when watching recordings. I have reset both the main q box and the mini on several occassions to no success. Anyone have any other tips or know what could be causing it? It has been working fine for months and there are no problems on the main q box.
Re: Sky Q mini box keeps freezing
Hi @JandL88
When you say you have reset both Q boxes what reset have you carried out?
Avatar for JandL88
@oldfella didn't explain that very well, I have switched off both boxes at the mains and restarted them main box first followed by mini.
Ok @JandL88
Try a Network Reset on the mini.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Avatar for JandL88
@oldfella this may have solved the issue, pressed the wps button on the router instead as this is nearer the mini box, so far no freezing. Will see how it goes.
