Discussion topic: Sky Q mini box connectivity problem after new Wi-Fi Max installed.
Message posted on 07 Jun 2024 04:28 PM
I have recently had the new Wi-Fi max rooter installed. I have one Sky q mini box in the spare room. When both devices are operational neither of the sky boxes work, it states connectivity issue.
When I unplug the the sky q mini box in the spare room the main sky box in the living room works perfectly.
I have gone through the instructions provided in the main website mutiple
times. Including resetting the sky q mini box from the main sky box.
Every time I reset the sky q mini it works initially for approx 3 minutes then I loose picture and it states connectivity issue. My broadband connection and Wi-Fi all work.
Is it an issue with the new Wi-Fi max rooter or an issue with the sky q mini box ?
thank you
Message posted on 07 Jun 2024 04:32 PM
							Re: Sky Q mini box connectivity problem after new Wi-Fi Max installed.
thank you
First try resetting your main Q box to your Network.
To reset your broadband router:-
When the main Q box is complete back up and running carry out the following:-
Reboot the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
Message posted on 08 Jun 2024 12:11 PM
Hi there, thank you very much for your helpful
tips. Very much appreciated.
i have worked through all options. Unfortunately the situation has not been resolved.
The main points I have learned is........
1/. Both the main sky box and the sky q multi room box do not work together while on at the same time.
2/. The sky q mini box was working when I pressed the reset button. However when I put the main box on in the other room it stopped working.
My view is that I need an engineer to resolve this issue.
Thanks again for your very useful hints and tips.
Message posted on 21 Sep 2024 03:40 PM
Did you manage to sort this issue, as I'm having the same problem. Was the engineer call out helpful?
