Discussion topic: No satellite signal
Message posted on 21 Sep 2024 03:23 PM
No satellite signal
I have rebooted everything but getting no satellite signal. Please help it's driving me mad
Message posted on 21 Sep 2024 03:24 PM
Re: No satellite signal
hi @Jay141
Please see the following page that covers a few problems - if you follow the link through and still have problems then you should find a link to book an engineer if you have your own dish
If you have a communal system you may have to contact your building management to deal with the technicians responsible for the system
Rebooting won't help. If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
