Discussion topic: Sky Q mini - apps buffering - annoying
This message was authored by: Jo+John
Hi,
Has anyone else had apps (Disney+, Apple) buffering when trying to watch something?
I've had a BT engineer to check the router and all is fine.  My Q box is okay and I've rebooted both, refreshed apps and it is still the same.
The Q mini box is in a room that has an outside wall between the Q box and the mini Q box, I can't ethernet connect it.  Is there a booster you can get for the Q mini as I know the Sky Q box creates its own signal.
Thanks,
Jo
This message was authored by: bemak187
Re: Sky Q mini - apps buffering - annoying
@Jo+John  The mini box only connects to the main q box not your router.  If the connection is not great between the mini and the main Q boxes you will get issues.  I assume that the apps all work ok on the main box?  Ethernet is always the best solution but if you are unable to run it there is a  booster that can be installed.  You will need to contact Sky and have an engineer come out, I think the Q boosters require a site visit.
Avatar for Jo+John
Thanks for the quick reply, I have booked an engineer.
