Discussion topic: Every time i try and use apps on my mini box it shuts down
This message was authored by: Tinajane65
Mini box shuts down when using either apps or recording
Re: Every time i try and use apps on my mini box it shuts down
Hi @Tinajane65
First thing to do is a Software Update to make sure the box is on the latest Software.
Home - settings - System info - Highlght Software version and then select Setup and then select Update this box with latest Software.
Any Q box (including minis) may require a manual software update at times.
For example a replacement Q box or mini or any box that is powered off when an update is released.
However bear if mind that when you select Setup (in Setting - System info - Software version) the message received will always be update this box with the latest software even if the box is already on the latest version.
Updating when already on the latest version achieves nothing and the box software is not refreshed.
All Q boxes and minis should be on the same software version.
See following links for latest Software versions and how to update Q software
https://www.sky.com/help/articles/sky-software-updates
https://www.sky.com/help/articles/updating-sky-box-software
