Discussion topic: Sky Q mini Box says subscription does not support this
This message was authored by: NeilHughes
When  trying to play recordings or select certain channels on mini box I get a message saying your subscription does not support this
Re: Sky Q mini Box says subscription does not support this
Hi @NeilHughes
Remember that Q minis do not handle UHD.
Avatar for NeilHughes
Level 0 icon
Thanks. I'm  not putting UHD through it. This was working before, but seems to have stopped this evening for some reason..
Hi @NeilHughes
Reboot the mini as above.
Level 0 icon
Thanks mate. Will try that.
