Discussion topic: Sky Q main box lost internet connection
This message was authored by: DeanoMariner
Sky Q main box lost internet connection (afternoon 2 Oct) and won't reconnect rendering my mini boxes useless!
I have tried all the suggested fixes, many times, and still won't connect.
My router is working fine, as are my laptops and phones connected to the network. Very frustrating!!
This message was authored by: Addie15
Re: Sky Q main box lost internet connection
Hi there, DeanoMariner. I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
This message was authored by: Tom-W19
Hi @DeanoMariner
An invite was sent but there was no response within 48 hours so it has automatically closed.
If you still need help with this please let us know by posting on the forum again and we will get it escalated through to us.
Tom
This message was authored by: brucey+boy
Hi
I am having the same issue here.
My Internet is working normally and fine for Laptops , Phones and SMART TV apps.
My TV works fine for channels including Sky, however if I go to Apps and select Netflix, Prime or others then i get not connected to internet.
I have followed the instructions to check Network (got a x) and reset it and go to the router to press the WPS button but the TV message just continues with the circle going around.
I have done all the switching off and back on again plus this setup has worked for a long time before.
This message was authored by: Snoopbenj
I have exactly the same problem not connecting at all for last hour
This message was authored by: Docat79
We have the same problem here today too.. WiFi to other devices in the home but no network connection to Q at all. We have tried disconnecting and resetting and following advice on the help page but nothing.
This message was authored by: sjch67
Same here, assumed it wad my system, restarted but no joy.
Great so tried to contact Sly and obvioulsy not operating as its the festive season.
 I assume some form of refund will be offered as the services are not fully operational.
Ours is still not working. Anyone else the same?
Mine too - has been not working for about 5 days now
This message was authored by: idol+the+bear
If you have Sky Broadband press the reset button on the back of the router (near the bottom) and wait for all the lights on the router to come back on Green. Then go back to the main Sky Q Box and search again for networks and your network should now show to connect to.
We've done that. More than once. Thank you though.
As you seem to be on Sky broadband, try the steps in post 7 here and have a look at 8 too
https://helpforum.sky.com/t5/Sky-Q/Sky-q-box-not-linking-with-Wi-Fi/m-p/4504698#M618552
