Discussion topic: Sky Q main box is stuck in standby.
Message posted on 03 Dec 2025 01:43 PM
Message posted on 03 Dec 2025 02:24 PM
Re: Sky Q main box is stuck in standby.
Hi @Paul-leah If you follow the help pages, it should lead you to requesting a replacement box (you will lose all your recordings). If a swap is required, remember to keep your viewing card and swap the power lead as well. https://www.sky.com/help/articles/sky-q-wont-turn-on
Message posted on 07 Dec 2025 09:50 AM
So, I'm guessing it cant be fixed, and my only option is a new box. That's incredibly disappointing, because i got a new box (losing all my recordings) and the new box has crashed within two days.
Is there anything I can do to stop my sky box crashing every few days?
Message posted on 24 Dec 2025 07:14 AM
Hi what happened tu your problem as I've now had 3 new boxes in as many weeks, 3 engineers and no one can fix the problem. The box goes on 'no signal' and starts whirring loudly. Last engineer came yesterday 23rd December and next engineer booked for 6th Jan. all useless so far and no answers or help to resolve the issue. About yjj oh cancel the whole thing.
Message posted on 24 Dec 2025 07:28 AM
I'm in the same boat. No one can tell me how to fix it.
Lost all my recordings from the original box when it got replaced, only to have the new box do exactly the same.
Box stuck in standby, loud whirring noise and getting warm. Resets when I unplug it from the power, but I have to do this every few days.
Message posted on 24 Dec 2025 09:05 AM
Sorry to hear this but I'm glad to find someone with the same problems. What Internet provider to you have? I have BT and have been told it's a problem with Sky Q and mesh network.
here's what they responded with but I can't believe how no one at sky can resolve this issue. What is modest irritating is that I had to way 2 weeks for an engineer who came yesterday 23rd December to find that even with a 3rd new box the problem persists. Now I have to wait till 6th Jan for another engineer who will also fail to fix the problem.
This is what BT sent me:
There isn't an official statement saying the BT Business Smart Hub 3 is outright incompatible with Sky Q but there are known issues with Sky Q and third-party routers (including BT hubs) that can cause problems. Here's what you need to know:
M Key Points
- Sky Q creates its own mesh network on 5GHz (Channel 36) for mini boxes and streaming. If your BT hub uses the same channel, it can cause interference and connectivity issues.
- Users with BT Smart Hub 2 have reported similar problems, which were fixed by:
- Turning off Smart Setup (BT's device wizard).
- Changing the 5GHz Wi-Fi channel from 36 to 44 or 48 to avoid conflict with Sky Q. [community.bt.com], [community.bt.com]
- Sky Q is generally sensitive to network setups and often works best with Sky's own routers. Many users report instability when using third-party routers, even over Ethernet. [helpforum.sky.com]
A Potential Issues with Smart Hub 3
- While there's no widespread report yet specific to Smart Hub 3, it uses similar firmware and Wi-Fi behavior as Smart
- Hub 2, so the same fixes likely apply.
- If you rename SSID or use custom passwords, some users have found Sky Q connectivity breaks until the hub is factory reset. (community.bt.com
Recommended Fixes
- Disable Smart Setup in the hub settings.
- Change 5GHz Wi-Fi channel from 36 to 44 or 48.
- Use Ethernet for the main Sky Q box if possible.
- If issues persist, consider using Sky's own router or a dedicated mesh system that avoids channel conflicts.
Message posted on 24 Dec 2025 12:52 PM - last edited: 24 Dec 2025 12:55 PM
It appears they sent you the AI output from an online search rather than an actual answer....
Message posted on 25 Dec 2025 11:56 AM
That's what passes for support these days
Any of you all using an EE router over ethernet?
