Discussion topic: Sky Q main box and mini box won't initialise
This message was authored by: CassieJ
Both my main Sky Q box and mini box won't start up.  Both have an amber light showing,  but nothing is happening.  I've tried turning them on and off etc, but the same problem is occuring.  I tried the Sky online diagnostic help, and it tells me there's a fault but of course I can't move forward as there's no error message being shown.  Any bright ideas??  Thanks
Re: Sky Q main box and mini box won't initialise
@CassieJ have you tried pressing the amber light as this is also the on button if that works on both boxes then it could be your remotes that are faulty
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
