4
This discussion topic has been answered Discussion topic: Sky Q losing broadband connection
This message was authored by: Boothie12
Broadband is fine in my house and every other device but it keeps losing connection on my sky box. I have to keep resetting every 5 mins and it's driving me crazy!! All other smart tvs are fine with Netflix etc but this sky box will not keep a connection. Any ideas? I have rebooted box, router and it has been like this for days
Avatar for Boothie12
This message was authored by: Boothie12 Answer
Re: Sky Q losing broadband connection
Thanks. I have tried that and also done a software update on the sky q box even though it said it was in the latest version, it updated and has been stable for an hour. Fingers crossed. Thanks
Hi @Boothie12
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
This message was authored by: Invisiblename
If the box is on the latest version of software then no update actually happens, it just causes it to carry out a full restart, like when you turn the power off at the wall.
I am just another Sky customer!
This message was authored by: Mansy2
Similar issues caused by a failing fast ethernet switch. Replaced it and all internet and mini box issues cleared.
Answered - Go to Answer
