13 Aug 2023 07:30 PM
So, my Sky Q has been behaving rather strangely for the past few weeks in that it loses internet connection every day at exactly the same time.
I have tried rebooting my Asus Zenwifi AX router and rebooting the box, this did not help.
I have tried the Powerline approach this didn't help.
Standby is set to off
It is all very strange.....
13 Aug 2023 07:38 PM
There is no Off for Standby.
Its either
When in None it's still necessary to switch the box into Standby with the remote when not in use (to amber led)
Anything (like heating) kick in at this time.
13 Aug 2023 07:45 PM
To confirm Standby is set to None and I do manually put the box into Standby when not in use. To my knowledge there is nothing special that happens such as heating coming on at this time.
As I say this has only started happening in the past few weeks - since I returned from four weeks overseas on holiday.
13 Aug 2023 07:47 PM
As @oldfella indicates, a classic cause of such a disconnection is the timer activation of a 'noisy' electrical device such as a circulation pump: when these start to go bad they can throw off an alarming amount of EMF (or simply cause a local power 'blip')
13 Aug 2023 07:48 PM
13 Aug 2023 07:50 PM
Thanks - will give this a go and let you know the outcome.
