9
This discussion topic has been answered Discussion topic: Sky Q lnb
This message was authored by: Phil3580
Sky Q lnb
I'm leaving sky for Freesat and  wanting to replace my sky Q lnb, I currently want to feed a 10 year old Samsung TV and 3 year old LG TV, a universal lnb works fine in both TV,s ,  but I will possibly add a 4k Freesat recorder and want to recorder 3 channels while watching one, do I need a hybrid lnb, TIA
This message was authored by: Godfrey Answer
Re: Sky Q lnb
If you want a Freesat 4K receiver to be able to record 3 channels whilst watching a 4th channel it will need to be connected to both the Vertically polarised channel outputs and the Horizontally polarised channel outputs of a Wideband LNB source.
Your Freesat TVs will require to be fed from a Legacy Universal LNB source.
So yes, you will need to change the existing Wideband LNB for a Hybrid LNB.
Godfrey.
Re: Sky Q lnb
hi @Phil3580
The Freesat 4K boxes work with both Universal LNBs as well as Wideband so you just need enough connections on a Universal LNB
Re: Sky Q lnb
Godfrey.
Re: Sky Q lnb
Godfrey.
oops I missed that aspect  - Sorry @Phil3580
Avatar for Phil3580
Re: Sky Q lnb
Thanks Godfrey, I had initially tried a universal quad LNB, that worked, so I ran a dual cable from the dish to the other TV in anticipation checked it out and that worked,  when I tried the SkyQ lnb I didn't get anything,  so in order to future proof it, I want to get the correct lnb, as I'm sure my wife will eventually want a 4k recorder, I've actually seen a hybrid on Amazon for £30,  Thanks again, appreciate your help, regards , Phil
Avatar for Phil3580
Re: Sky Q lnb
Hi Nigel, am I correct in saying if I use a universal lnb, I can only record one channel while watching another, TIA Phil
Re: Sky Q lnb
hi @Phil3580
Yes universal LNB feeds work with a voltage change and presence or not of a 22Khz tone to select polarity & hi/lo bands, meaning only a approx 1/4 channels are available to the feed.
Whereas the twin cables of a wideband feed providing a polarity each with all frequencies means all frequencies/polarities are always available  leading to have more  tuners that can be used to record at the same time
Avatar for Phil3580
Re: Sky Q lnb
Thanks Nigel, would you agree with Godfrey, a hybrid lnb is the solution, TIA Phil
Re: Sky Q lnb
Yes - Sorry I didn't make that clear in my earlier response
Avatar for Phil3580
Re: Sky Q lnb
Thanks for your help Nigel, enjoy your day, Regards Phil
