Discussion topic: Can't connect broadband hub to sky tv
This message was authored by: NanaLoza-
Had a new broadband hub but can't connect sky q to broadband
Re: Can't connect broadband hub to sky tv
Hi @NanaLoza-
If you have the New Sky Max hub then it need to connect your Q box as if it is 3rd party broadband.  (ie use SSID and password)
