This discussion topic has been answered Discussion topic: Sky Q keeps re-enabling WiFi when connected via ethernet
Message posted on 18 Feb 2025 03:52 AM
So I have a sky Q box connected via Ethernet and a sky mini box connected via WiFi.
When I turn off the WiFi on my Q box it switches to showing a different SSID for a few minutes but then seems to switch back to the WiFi SSID and when I go back in to check the WiFi has re-enabled itself.
is this because the mini box is still connected via WiFi?
I thought the mini box connects to the Q box rather than WiFi or does it need WiFi to connect to the Q box.
im confuzzled.
thanks in advance.
Message posted on 18 Feb 2025 05:35 PM
When I turn off the WiFi on my Q box it switches to showing a different SSID for a few minutes but then seems to switch back to the WiFi SSID and when I go back in to check the WiFi has re-enabled itself.is this because the mini box is still connected via WiFi?
im confuzzled.
thanks in advance.
@Speedytriple The mini box if connecting by wifi needs to connect to the Q mesh (generated by the main Q box if your broadband is not Sky) on a 5Ghz wifi connection so yes you need to have wifi switched on, on the main Q box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
im confuzzled.
thanks in advance.
Message posted on 19 Feb 2025 04:22 AM
Re: Sky Q keeps re-enabling WiFi when connected via ethernet
Thank you.
