This discussion topic has been answered Discussion topic: Sky Q keeps on stalling.
Message posted on 25 Jul 2023 06:01 PM
For the past few weeks i have been having major problems with my Sky Box.
The problem developed when switching to various channels would take LITERALLY 10 seconds or more, during which time the screen would go black until the channel would eventually come on.
This started happening more and more, and now we are at a stage where the box freezes every few hours when trying to turn over.
Message posted on 25 Jul 2023 06:47 PM
@Slainagain wrote:
Have already tried this, makes no difference.
Looks like your best bet is to contact Sky for an Engineer then @Slainagain
Message posted on 25 Jul 2023 06:12 PM
Re: Sky Q keeps on stalling.
And when this happens the only way to sort it is to turn off at wall and reboot, which only sorts the problem for a while before we go round again.
Message posted on 25 Jul 2023 06:27 PM
Hi @Slainagain
Try a Reset Settings in the Q box hidden menu. It may help.
Message posted on 25 Jul 2023 06:44 PM
