Discussion topic: Sky Q keeps forgetting 3rd party network credentials
This message was authored by David-Savage This message was authored by: David-Savage
I have just had Sky Q installed as an upgrade and it has an issue where it keeps forgetting the 3rd party network credentials.
We have Sky broadband, but use a mesh network to boost the wi-fi signal around the house.
I do a reset and select the mesh network name and enter the password and it connects ok.
But after about 2 minutes it disconnects, forgets those credentials and wants to keep connecting to the Sky router, which is out of range for a decent connection.
Does anyone know how to make it not forget the settings I keep adding?
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: Sky Q keeps forgetting 3rd party network credentials
Is there a mesh node nearby with an ethernet port?
Q doesn't always play nicely with mesh networks wirelessly.
David-Savage
Thanks. There is an ethernet port on the disc, but that disn't work either unfortunately.
I've ordred a Sky Q booster. Hopefully that will do the trick.
Thanks for your help
